I’m trying to keep the entire <head> section within a Content Fragment, so I created a dedicated CF and included it in the content template. However, after saving and reopening, the CF is automatically moved from the <head> tag to the <body> tag.
Before save,
<!DOCTYPE html>
<html data-qb-installed="true">
<head>
<meta charset="utf-8" />
{{fragment id='ajo:ce84ac85-7f5b-4385-84cf-f3c850da8140' mode='inline'}}
<header></header>
<div>test</div>
</body>
</html>When I reopen the same,
<!DOCTYPE html>
<head>
</head>
<body class="is-html-mode" contenteditable="true">
<header></header>
<div>test</div>
</body>
</html>
The inserted Content Fragment is being moved from the <head> tag to the <body> tag after saving. Is it not possible to insert a Content Fragment within the <head> section
@Mario248 Yes.
@Mario248 Yes.
Thank you for the detailed response.
The reason I created a Content Fragment was to include custom meta tags within the <head> section, which also contains CSS references. My goal is to keep all CSS and meta details in a separate Content Fragment so that they can be managed easily without modifying the actual body content.
However, I’m wondering if this approach aligns with best practices. Is it recommended to maintain CSS in a separate file and reference it instead? If using a Content Fragment isn’t the right approach, where is the best place to maintain and include CSS within a Content Template? What’s the recommended best practice for managing CSS in this context?
@Mario248 For AJO email templates, it is not considered best practice to maintain CSS in a separate file and reference it, as this approach may not be supported by email clients. The recommended best practice is to use inline CSS for each fragment.
