Trying to import issues into a project and am coming across this error when it comes to the setProjectID column. I have tried the project ID from the URL and the project reference number, without success. The project is in Current status. Appreciate any suggestions.
In our Excel Updater solution, we use a similar "pound set" (aka VLookup) technique which you can read about here, in case it gives you a clue.
That said, if you do have the Project ID in question in hand, I suspect it might be as simple as changing the column header from setProjectID to just projectID.
Thanks Doug. I thought for sure I needed "set" before any field when doing a kickstart, but when I went back to look at my spreadsheet to try your suggestion I realized I had a # before the text in my kickstart template, so thank you for having me take that 5th look! setProjectID and the project ID from the URL worked that time. It's the tiniest things that make or break a kickstart!
