Your achievements
0% to
Tip /
Sign in
Sign in to Community
Bedrock Mission!
Learn more
View all
Sign in to view all badges
ADEP Designer 10 - Help does not work
I recently installed ADEP Dedigner 10 (before i used Livecycle Designer ES2),
When i now press F1 to get the Help function nothing happens the only thing is that the application is getting freezed for a couple of seconds.
In the folder which seems to be responsible for the Help function (C:\Program Files (x86)\Adobe Digital Enterprise Platform\Designer 10.0\Documentation\EN) is no file exceipt of "Readme.htm". In the same folder in Livcecycle Deigner ES2 there is a "Designer.chm" Help file which is opened when F1 is pressed?
Has anybody a solution for me to get the help function working?
Are you connected to the internet?  When you press F1 in Designer 10 is brings up Adobe Community Help
http://help.adobe.com/en_US/enterpriseplatform/10.0/DesignerHelp/index.html
Yes my computer is connected to internet. For example when i click on "Adober Developer Connection" in the help menu the Adobe Dev site is opened.
I have no idea why the F1 help isn't...
Yes when i hit your posted link the ADEP Designer help opens.
