Adobe Analytics Champions applications are now OPEN! Applications are open through June 2nd. Click the link to learn more and apply.
Data Element | Custom Code | Products info
Hi Community,
I have trouble retrieving information from a data element.
I try to retrieve the value of the "condition" variable of my products in a data element "Adobe Analytics - Product - Condition".
Here are some screenshots to explain what I did:
Here is the custom code inside:
Returns 1 if the value is "new", else if it's "used" return 0.
var productCondition;
switch (true){
  case (digitalData.product[0].attributes.condition === "new"):
    productCondition = 1;
    break;
  case (digitalData.product[0].attributes.condition === "used"):
        productCondition = 0;
        break;
return productCondition;
What I can see from the console is the following:
First I tested the code itself. Then I just tried to call my Data Element.
I'm getting the expected result with the code, but when I call the Data Element, it says it's likely setup incorrectly.
I don't get why. I pushed my data element in my development environment. I'm doing my tests on my development website but I'm not understanding the error here.
Does anyone has any suggestions here please ?
Hi @yuhuisg & @Charles_Thirupathi,
Thanks for the cleaner code shared @yuhuisg, really appreciated!
@Charles_Thirupathi Thanks for sharing those tips to check the property AND the environment. It helped me to find the issue.
In fact we have 2 channels on the development environment. And my modifications were published on the channel2. But I was checking the Channel1.
In case it can help anyone else, here are the steps I went through :
I used the Adobe Experience Platform Debugger to switch the channel.
So I went in the Launch tab on the left, then clicked "Actions"
Then I just had to select my property (1) and the correct channel (2).
Firstly, that code looks like an "abuse" of the switch statement. I'd rewrite it like so:
switch (digitalData.product[0].attributes.condition) {
  case "new":
    break;
  case "used":
    break;
Anyway, you can try debugging further by setting the initial value of productCondition to your product's condition attribute, i.e.
var productCondition = digitalData.product[0].attributes.condition;
and see if that condition gets returned, instead of "undefined", when you run _satellite.getVar().
Hi Swanan,
Have you verified property and environment of the Launch Embedded Code present in the page your testing? if not kindly verify using syntax's _satellite.environment.stage & _satellite.property.name. The reason for  undefined may be the Data Element your testing is not deployed in the respective Environment you're testing. Also verify the DataElement Name you've provided in _satellite.getVar() syntax(better copy the name from the dataelement you've created).
If any of the above doesn't resolve the issue kindly share the URL so that i can check and able to find the issue.
Charles
page footer
