Come join us for our Coffee Break this WEDNESDAY on top takeaways from Adobe Summit!
Problems with ticketing system?
Level 7
Is there ongoing issue with ticketing system?
I cannot submit a new one:
dropdown where I would normally select Workfront is empty...
tagging @jon_chen
@Rafal_Bainie
Thanks @AshleyNe1 for confirming that this is a known issue. If our support team is addressing this issue - you should be able to see an update on the Workfront Known Issues page shortly.
Yes I called earlier today and verified that this is a known issue
@Rafal_Bainie
