Don’t miss the AEM Skill Exchange in SF on Nov 14—hear from industry leaders, learn best practices, and enhance your AEM strategy with practical tips.
GREP PROBLEM? Attribute parts of one fields rawvalue to other fileds
Former Community Member
I am trying to find a way to divide the rawvalue of an input field into its component words
so if field A has a vlaue of "Julia Alison Child"
i would like to be able to cut that up into Firstname Middlename and Lastname fileds
I susepct it can be done using grep by determining when the first and second spaces occur
and taking everything before that for field onei.e Firstname
everything after that and before the second for Middlename and everythign after the second space for Lastname.
Conseptually it's simpe enough but I cant scavange a workign code sample and my coding isnt up to the job
anyone seen anythign like this before?
try this method.
var Input = Textfield1.rawValue;
var NameParts = Input.split("\u0020");
if (NameParts.length === 1)
FirstName.rawValue = NameParts.slice(0,1).toString();
MiddleName.rawValue = "";
LastName.rawValue = "";
if (NameParts.length === 2)
LastName.rawValue = NameParts.slice(1,2).toString();
if (NameParts.length === 3)
MiddleName.rawValue = NameParts.slice(1,2).toString();
LastName.rawValue = NameParts.slice(2,3).toString();
try this method.
Hi Radzmar - thanks for the code - perfect.........
