How to call offer engine using SOAP
How to get Offer Engine (Propositions) via SOAP instead using a Java Script code?
In the documentation, at this url:
https://docs.campaign.adobe.com/doc/AC6.1/en/ITA_Unitary_interactions_Calling_the_offer_engine__inbo...
Is stated to use url like this:
https://ac284eu.adobesandbox.com/interaction/liveAnon/webAnon
But how's possible to get the wsdl in order to use tools like SoapUI to investigate the available methods?
Unfortunately there is no WSDL to call Interaction. The Javascript code in the documentation is actually building a soap call. You should be able to call the Interaction engine with a call like this
Get propositions:
<?xml version='1.0'?> <SOAP-ENV:Envelope xmlns:SOAP-ENV='http://schemas.xmlsoap.org/soap/envelope/'> <SOAP-ENV:Body> <Propose> <targetId>xxx</targetId> <maxCount>1</maxCount> <context><interaction/></context> <!--optional--><categories></categories> <!--optional--><themes></themes> </Propose> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
Update proposition status:
<?xml version='1.0'?> <SOAP-ENV:Envelope xmlns:SOAP-ENV='http://schemas.xmlsoap.org/soap/envelope/'> <SOAP-ENV:Body> <UpdateStatus> <proposition>1242</proposition> <status>3</status> </UpdateStatus> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
Best regards,
Thomas
Get propositions:
Best regards,
Thomas
Thank you very much, i've made some test using PostMan and it works fine!
Hi aveggiani47deck​,
I am trying the same , wanted to know if you could share some examples.
Shiva
Hi thomasb1964232
Is there any possible ways to use <context/> parameter with the update step? I want to update few more fields apart from <status></status field>
Somasundaram
