I found on the Adobe site that recommendation engine is for personalized content, but I am not able to understand the difference between Adobe Recommendation Engine and Adobe Target.
Appreciate your support.
Abhishek
@abhishegupta As indicated below, product and content recommendations is a component to Adobe Target. You can find the documentation here: https://experienceleague.adobe.com/docs/target/using/recommendations/recommendations.html?lang=en#te...
Magento Commerce also has some native product recommendations capability in their commerce tool: https://magento.com/products/product-recommendations
Adobe Target is the Adobe Experience Cloud solution that provides everything you need to tailor and personalize your customers’ experiences. Target helps you maximize revenue on your web and mobile sites, apps, social media, and other digital channels.
In Adobe Target Premium you can create 5 different activities:
1. A/B n Tests
2. Experience Targeting
3. Automated Personalization
4. Multivariate Tests
5. Recommendations.
Adobe Target tool gives you the option to create/run recommendations on your website.
Adobe Target Recommendations activities automatically display products, services, or content that might interest your visitors based on previous user activity, preferences, or other criteria. Target Recommendations helps the direct visitors to relevant items they might otherwise not know about. Recommendations let you provide your visitors with relevant content at the right time and in the right place.
Hi @abhishegupta ,
What Adobe recommendations do is, it has own high quality and accurate algorithm created and we just need to feed the data to algorithms (criteria) and target will personlise experience for user as per his behaviour or his past behaviour on site..
Whereas in Adobe target without recommendations thr r other activities present such as A/B test, experience test, mvt, Ap etc. Which you can use to create multiple experience to compare different designs or other attributes related to your website.. also you can these activities to retargeting customers by creating different set of audiences and use them in xt test.. with help of AP you can perform advance level optimization.
