내 커뮤니티 업적 표시줄을 확대합니다.
Not able to author adaptive forms in universal editor aem edge delivery services
I am writing to report an error we are experiencing while authoring adaptive forms in universal editor. Please find the below error occurs while trying to author Adaptive forms in universal editor,
other:java.base/java.lang.Thread.run(Thread.java:1583), 2% HTTP-POST:/content/eds-poc3/forms/jcr:content/root/secti...] [CommitStats overhead was 2ms = 59.0us / commit]
09.01.2025 23:20:00.655 [cm-p51328-e442308-aem-author-55577c4448-zb7sl] *ERROR* [13.113.45.32 [1736464799542] GET /content/eds-poc3/forms/jcr:content/root/section_727041587.html HTTP/1.1] com.day.cq.wcm.core.impl.WCMDeveloperModeFilter Error during include of SlingRequestPathInfo: path='/content/eds-poc3/forms/jcr:content/root/section_727041587/form_896591219', selectorString='null', extension='html', suffix='null' org.apache.sling.scripting.sightly.SightlyException: Compilation errors in org/apache/sling/scripting/sightly/libs/fd/franklin/components/form/v1/form/form__002e__html.java:_Line 40, column 1814 : com.adobe.cq.forms.core.components.models.form.FormStructureParser cannot be resolved to a type.
주제
토픽은 커뮤니티 콘텐츠를 분류하여 관련성 있는 콘텐츠를 찾는 데 도움이 됩니다.
3 답변 개
Hi Janani,
I hope the Forms add-on is already enabled in your environment. Could you please ensure you are using the latest version of the Forms Core Component?
Yes, Forms add on is already enabled & I have recently enabled forms core components. Please find the below screenshot for reference,
Also Please find the attached maven build issue error logs which we got while deploying the code after enabling form core components.
The issue is resolved now. Thanks
