what will happen if dont define autopk=true on main element of data schema in ACC | Community
  • January 30, 2024
  • 484 views
@ParthaSarathy
@ParthaSarathy
@ParthaS
@AkshayAnand
@Craig_Thonis
@Manoj_Kumar_
@Amine_Abedour
@Marcel_Szimonisz
@DavidKangni
@Amit_Kumar
@ShashankNigam02
@Ganesh5067
@Jonathon_wodnicki
1.what will happen if dont define autopk=true on main element of data schema in ACC
2.what will happen if i define autopk=true on main element of data schema in ACC
Best answer by ParthaSarathy
@dishasharma , Primary key is mandatory in a schema. If you don't have any dedicated attribute for primary key, then you can define autopk="true" which will create an attribute @id with datatype as long and whenever a new data get inserted into this schema, @id will keeps on incrementing.
If you have a dedicated primary key in your schema, then you don't have to add autopk="true", instead you can create primary key using your attribute with below syntax
<key name="PrimaryKey" internal="true">
  <keyfield xpath="@name"/>
</key>
ParthaSarathy
ParthaSarathyCommunity AdvisorAccepted solution
</key>
