Jan 29, 2025 7:53 PM UTC
Best Practices for setting up environments for production level EDS website
Hey everyone,
We have an EDS website which we want to deploy on our AEM Cloud CDN using Edge Delivery Solution. (Screenshot below)
I do understand the steps needed to configure and connect an EDS website to a Domain. However, this single domain instance will then be our production. I want a staging environment before in this pipeline, so it should somehow look like this:
main----.aem.live ---> www.stagingURL.com ----> www.productionURL.com
Is that pipeline possible in this configuration for EDS? What are the recommended best practices?
Thank you 🙂
Tad_Reeves
Tad_ReevesAccepted solution
Adobe Champion and User Group Leader
Feb 3, 2025 1:09 PM UTC
Great question.  I'm assuming that you already have a CDN configuration underway to be able to map your domain to your main--[yoursite].aem.live domain.  If not, I put a bunch of sample CDN configurations for such in a blog post.
But if you want a staging URL, like www-stage.mysite.com, there are two different ways you can map this.  If you're interested in having a CDN in front of the staging CONTENT, you can use the CDN configuration to map to your .page URL to a separate domain using originSelectors in your CDN YAML.  You also may want to make a staging URL that instead uses a specific branch in your code to test that staging branch through the CDN, i.e. something like this:
originSelectors:
    rules:
      - name: staging
        when: { reqProperty: domain, like: www-staging.mysite.com }
        action:
          type: selectOrigin
          originName: mysite-staging-url
    origins:
      - name: mysite-staging-url
        domain: stagingbranch--projectname--siteowner.aem.live
        forwardHost: false
Hope that helps!
kautuk_sahni
Level 9
Feb 3, 2025 12:32 PM UTC
@h_kataria@shashi_mulugu@kapil_rajoria@tad_reeves@uppari_ramesh@riteshy18@joerghoh@anil_chennapragada@arunpatidar@cr17506599
Kindly take a moment to review this question and share your valuable insights. Your expertise would be greatly appreciated!
Translate
Tad_Reeves
Tad_ReevesAdobe Champion and User Group LeaderAccepted solution
originSelectors:
    rules:
      - name: staging
        action:
          type: selectOrigin
    origins:
        forwardHost: false
Hope that helps!
Translate
