Sorry having problems getting any value, true or false for the following script, and not sure why.
displayname=Delivery Date
listdelimiter=<p>
listmethod=nested(tasks).lists
textmode=true
type=iterate
valueexpression=IF(CONTAINS("Shipping Ocean",{Project}.{Task}.{name}),{"dueDate"},"0"))
valueformat=HTML
Hi @RichardCl1 - I would give the below a try! Let me know if it doesn't work.
listdelimiter=<div>
textmode=true
type=iterate
valueexpression=IF(CONTAINS(“Shipping Ocean",{name}),CONCAT({plannedCompletionDate}),"")
valueformat=HTML
listdelimiter=<div>
textmode=true
type=iterate
valueexpression=IF(CONTAINS("Shipping Ocean",{name}),CONCAT({plannedCompletionDate"),"1")
valueformat=HTML
The above isn't returning any values still. I stold the script from an example that was somewhat similar on the board, unfortunately still not getting it done.
My concern here is that this is a project level report, and I'm trying to run the IF statement at the Task level, to return the due date for the task.
If I replace the Concat portion with a fixed value it returns a true statement value, so that's good, but I can't seem to get it to return the date, and it seems to return multiple true values for the single project line.
listdelimiter=<div>
textmode=true
type=iterate
valueexpression=IF({task},{name}="Delivery Gate Meeting and Approval","2","1")
valueformat=HTML
listdelimiter=<div>
textmode=true
type=iterate
valueexpression=IF(CONTAINS(“Delivery Gate Meeting and Approval",{name}),CONCAT({plannedCompletionDate}),"")
valueformat=HTMLThe one you have above appears to be returning the number of tasks from the project with the value as 2. I'm surprised the one above doesn't work...I adjusted the task name to match what you have in the reply.
This is just strange, I can't figure out why this isn't working, it should be. Is it that this is a project report and it doesn't see that I'm looking for the Task Name field? And the Task COmpletion date field?
I don't think you need the CONCAT. That allows you to combine things, such as showing both the Planned Complete Date and something else.
Also be VERY careful, when you copy/paste anything with quote marks into the text mode box, make sure you replace any curly quotes with straight quotes
try this:
listdelimiter=<p>
textmode=true
type=iterate
valueexpression=IF(CONTAINS("Delivery Gate Meeting and Approval",{name}),{plannedCompletionDate},"")
valueformat=HTML
