Your achievements
0% to
Tip /
Sign in
Sign in to Community
Bedrock Mission!
Learn more
View all
Sign in to view all badges
Problems using rpc between Flex and CF
Hi
I've got a problem sending objects between Flex and
Coldfusion using the AMF Gateway of the newest Coldfusion Version.
The transfer from CFC to Flex does work, but I can't send a
complex object to a CFC.
The error Message is:
faultCode:Client.Message.Encoding faultString:'Cannot create
class of type 'flex.HotlineSystem.bin.cf.Category'.'
faultDetail:'Type 'flex.HotlineSystem.bin.cf.Category' not found.'
Im totally going nuts ... the transfer from CF to Flex is
working fine, the mapping between category.cfc and category.as ist
working. But If I try to send an category Object from Flex to my
CFC it is not.
Hope someone can help.
Merci!
CFC Function:
<cffunction name="insertCategory" access="public"
returntype="void" output="false">
<cfargument name="category"
type="flex.HotlineSystem.bin.cf.Category" required="true">
<cfquery name="insertCategory"
datasource="hotline_system">
INSERT INTO category (category_idCategory, name)
VALUES ( #category.getCategory_IdCategory()#,
'#trim(category.getName())#')
</cfquery>
category.cfc:
<cfcomponent displayname="Category"
alias="flex.HotlineSystem.bin.cf.Category" hint="I model a single
Category">
<cfproperty name="idCategory" type="numeric"
default="0">
<cfproperty name="category_idCategory" type="numeric"
default="0">
<cfproperty name="name" type="string" default="">
<cfscript>
//Initialize the CFC with the default properties values.
variables.idCategory = 0;
variables.category_idCategory = 0;
variables.name = "";
</cfscript>
<cffunction name="init" output="false"
returntype="flex.HotlineSystem.bin.cf.Category">
<cfreturn this>
</cffunction>
<cffunction name="getIdCategory" output="false"
access="public" returntype="any">
<cfreturn variables.IdCategory>
</cffunction>
<cffunction name="setIdCategory" output="false"
access="public" returntype="void">
<cfargument name="val" required="true">
<cfif (IsNumeric(arguments.val)) OR (arguments.val EQ
<cfset variables.IdCategory = arguments.val>
<cfelse>
<cfthrow message="'#arguments.val#' is not a valid
numeric"/>
</cfif>
</cffunction>
<cffunction name="getCategory_idCategory" output="false"
<cfreturn variables.Category_idCategory>
</cffunction>
<cffunction name="setCategory_idCategory" output="false"
<cfset variables.Category_idCategory = arguments.val>
<cfelse>
numeric"/>
</cfif>
</cffunction>
<cffunction name="getName" output="false" access="public"
returntype="any">
<cfreturn variables.Name>
</cffunction>
<cffunction name="setName" output="false" access="public"
returntype="void">
<cfset variables.Name = arguments.val>
</cffunction>
</cfcomponent>
category.as:
package classes
[Bindable]
[RemoteClass(alias="flex.HotlineSystem.bin.cf.Category")]
public dynamic class category
public var idCategory:int;
public var category_idCategory:int;
public var name:String;
public function category(){
public function fill(idCategory:int,
category_idCategory:int, name:String):void{
this.idCategory = idCategory;
this.category_idCategory = category_idCategory;
this.name = name;
public function getIdCategory():int{
return this.idCategory;
public function setIdCategory():void{
public function getCategory_IdCategory():int{
return this.category_idCategory;
public function
setCategory_IdCategory(category_idCategory:int):void{
public function setName(name:String):void{
this.name = name;
public function getName():String{
return this.name;
Problem solved:
It is apparently not possible to transfer an object of an
action script class to coldfusion.
The solution is to encapsulate the object (in my example
category) in an array.
Strange, ... but it works.
best regards
Not applicable
The top level flex.* package is reserved for Flex only, you
cannot use this
with ColdFusion CFCs.
Not applicable
That is, try a different package name for your CFCs to
something other than
flex.*
Pete
Hi
first of all: thanks for replying.
I changed the package to "da.HotlineSystem.bin.cf.Category"
and my webdirectory to
"..\CFusionMX7\wwwroot\da\HotlineSystem\bin\cf", but there is still
the same error message:
class of type 'da.HotlineSystem.bin.cf.Category'.'
faultDetail:'Type 'da.HotlineSystem.bin.cf.Category' not found.'
I changed the CFC argument types to any but it makes no
difference.
I think it has something to do with the mapping between the
category.as and the category.cfc
Did I forget anything in my cfc or as files?
Heres my service.config.xml from
CFusionMX7\wwwroot\WEB-INF\flex
<services-config>
<services>
<service id="coldfusion-flashremoting-service"
class="flex.messaging.services.RemotingService"
messageTypes="flex.messaging.messages.RemotingMessage">
<adapters>
<adapter-definition id="cf-object"
class="coldfusion.flash.messaging.ColdFusionAdapter"
default="true"/>
</adapters>
<destination id="ColdFusion">
<channels>
<channel ref="my-cfamf"/>
</channels>
<properties>
<source>*</source>
<!-- define the resolution rules and access level of the
cfc being invoked -->
<access>
<!-- Use the ColdFusion mappings to find CFCs, by default
only CFC files under your webroot can be found. -->
<use-mappings>true</use-mappings>
<!-- allow "public and remote" or just "remote" methods
to be invoked -->
<method-access-level>remote</method-access-level>
</access>
<property-case>
<!-- cfc property names -->
<force-cfc-lowercase>false</force-cfc-lowercase>
<!-- Query column names -->
<force-query-lowercase>false</force-query-lowercase>
<!-- struct keys -->
<force-struct-lowercase>false</force-struct-lowercase>
</property-case>
</properties>
</destination>
</service>
</services>
<channels>
<channel-definition id="my-cfamf"
class="mx.messaging.channels.AMFChannel">
<endpoint uri="
http://{server.name}:{server.port}{context.root}/flex2gateway/"
class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>true</polling-enabled>
<serialization>
<instantiate-types>true</instantiate-types>
</serialization>
</properties>
</channel-definition>
</channels>
<logging>
<target class="flex.messaging.log.ConsoleTarget"
level="Error">
<properties>
<prefix>[Flex] </prefix>
<includeDate>false</includeDate>
<includeTime>false</includeTime>
<includeLevel>false</includeLevel>
<includeCategory>false</includeCategory>
</properties>
<filters>
<pattern>Endpoint.*</pattern>
<pattern>Service.*</pattern>
<pattern>Configuration</pattern>
<pattern>Message.*</pattern>
</filters>
</target>
</logging>
<system>
</system>
</services-config>
Nobody?
hm, .. is it possible to send complex objects from flex to
coldfusion, or is it only possible to consume?
Problem solved:
best regards
Not applicable
Ah right, the issue is that ColdFusion supports two styles of
providing arguments
to CFC functions - ordered arguments and named arguments.
If you call your RemoteObject method with a single complex
object it thinks
you are providing a Struct of named arguments. This is a
legacy feature from
the original Flash Remoting functionality and CFCs. There are
several work
arounds... wrapping it in an Array is one such workaround,
another is to
simply provide a second argument so that it will think the
complex object
is just the first ordered argument rather than a struct of
named arguments.
