I planning to develope a sample application using Selection and Capture building block. I am new to this concept, Please can any one help me Step by Step process to develop the application.
Thanks in advance.
Can you please share more information about the application you are trying to build using SNC.
Hi AnkitY,
As of my knowledge I am planning like.
I have one selector : having two radio button options:
1 . New Registration
2. Existed User
If user selects the New Registration I need to provide the Registrationform.PDF as service.
If user selects the Existed User I need to provide Appointment.pdf as service.
please tell me is it a good idea and am I in the right path?
I am very new to this concept I am not getting even how to start this application. Please give me some idea and steps to develope this kind of application.
Thanks in advance.
The use case described can certainly be implemented using SNC. All you need to do is to create a config-bean and deploy it.
You can use the sample-config bean shipped along with SNC for the various constructs supported by SNC.
Regarding the other problem about starting the application. Please let me know which build of SNC are you using?
In my LiveCycle Workbench tool SNC 1.0 is installed.
sorry for asking simple doubts, My doubt is Where I have to create the config-bean.xml ? If possible please share with me sample config file.
and I have to deploy the config-bean.xml file in server is it.
Thanks in advance.
config-bean is a simple xml file, the deploy instructions are available at http://help.adobe.com/en_US/sa/snc/snc_techdoc_help/index.html?content=snc-whatsIn_1.html.
Sample config bean is available at sa/building_blocks/snc_2_0/resources/snc_portal/adobe-bb-snc-sample-config-beans.xml in the snc distributable.
