Adobe Summit 2025: AEM Session Recordings Are Live! Missed a session or want to revisit your favorites? Watch the latest recordings now.
Help with Body Text Field...
Ok so far so great, till....
I just finish building a complex for for my Company. Within this form I created a page wide Square Text box field. My problem is so simple but still I have not being able to fix.
as you type in the active form, the txt continue to go on on the first line and not able to scroll or continue to the second line, it just keep going on beyong the frame of the Txt box field....
Any Idea?
Caleb
Former Community Member
Now I need to see the form ...can you email it to LiveCycle8@gmail.com and indicate which field is causing you grief.
Paul
Did you set the field as a multi-line field? On the object palette there is a checkbox for this:
Paul
I have that check but Still... no Dice...
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
