Anyone know how to run a report to find out how many time this was clicked? Can't find it anywhere on Omniture! Thanks
Hi Kitty,
If you have not tracked it, then most likely there is no data for it. You need to send a custom link tracking when you clik on the link. Here is the doc on how to do it :
http://microsite.omniture.com/t2/help/en_US/sc/implement/link_functions.html
Best regards.
Alexis Cazes
Hi Kitty,
Best regards.
Alexis Cazes
